Proto48 GP9
Started by sbranstetter, December 03, 2016, 02:52:38 PM
sbranstetter
I've begun work on a Red Caboose GP9 in Proto48. I've always wanted to detail the underframe so I've decided to give it a try. I'm using a custom milled steel frame for weight and wrap styrene around it.
Shawn Branstetter
shortlinemodelers.com
sbranstetter
Cutting the side skirts to expose the details and milling the plastic to thin it out. Hoping this looks more like sheet metal when done.
Shawn Branstetter
sbranstetter
Wrapping sheet styrene around the steel.
Shawn Branstetter
sbranstetter
A view from the side.
Shawn Branstetter
sbranstetter
I sprayed the underside to expose any spots that need cleaned up. I'm hoping to start on the pipe details soon.
Shawn Branstetter
Thanks for posting your progress, Shawn. I look forward to the next installment. -- Russ
Very clean work, Shawn, looking good.
sbranstetter
Thank you. I've just ordered 4 Magic Carpet drive from North West Short Line to hopefully give this the look and feel of traction motors. As for now, I've spent last night sketching pipe locations for the underframe.
Shawn Branstetter
sbranstetter
Shawn Branstetter
