Construction Station "Schwarzburg" Faller Kit
Started by ximo, December 28, 2008, 01:07:46 PM
ximo
Some photos of the process of construction and decoration of this nice station...
Regards ximo.
lucas gargoloff
It´s a nice model, and you´re doing a good work to change the "plastic look" of it. I saw many Spanish models in your rooster are you from there?
Regards
Lucas
Lucas Gargoloff - Argentina
I think this is coming along nicely. I do wish there was some more verigation/variation in the shading and coloring of the vines/foliage on the walls,....and that the joints/seam at the wall corners had been filled better, so that they were not so visible. this is particularly annoying since the stone blocks wrap/continue around the corners in a real building.
ximo
Thank you very much for your answers and suggestions, if I'm Lucas of Spain, this model is specifically for Austria but I'm changing.
Regards ximo.
