Fordson tugger hoist
Started by Chuck Doan, January 10, 2017, 09:04:51 PM
looking good and so realistic
For me Chucks work is a phenomenon. I will be honest: At first sight all I saw was a pinkish engine piece with some heavy chipping - not very spectacular! And I remembered the same thought I had some time ago at post 94 of this thread.
To me it seems, Chuck knows exactly what is of importance at that very moment and is not afraid of doing steps, I would never dare to do. I have reflected on my modelling and came to the conclusion that I have always the right balance at every moment in mind and so most likely miss some very important extremes that are important on the way to such a results Chuck can archieve. Hmm, very difficult for me to explain in English... :-[
It is quite simple: Chuck himself is a phenomenon. He not only sees every relevant detail but has the skill and artistry to reproduce every one and to combine each part into an exquisitely realistic and convincing whole. Frankly, it's just disgusting. -- Russ
Actually I find Chuck's work rather disappointing . If you are going to go the trouble of getting the machine looking perfect with all specially manufactured parts you might as well go the whole hog and make the engine work . After all how much extra work would it take to run up a few valves and pistons etc.?
   Sad to say that I think we might have to re-evaluate Chuck's status of superhero !
Well, I am not returning the cape!
Thanks for the nice words. Nick, I did come across pictures of a 1/4th scale fully functional Fordson, but model engineering is beyond me.
Painting and weathering is always daunting to me.  It's fun when it works but it often doesn't, so I plan to fail. The initial coats will sluff off nicely in a vat of Windex. The weathering is done with pigments and Prismacolor pencils; both things that can be readily altered or removed. I also tend to paint and weather items separately, so If I don't like something I can strip it or whatever before I add it to the model.  The tractor body is the single largest piece, so finishing it (and liking it) will be a big step.
I am finally beginning to add parts and start the weathering process on the tractor.  I'm starting on the rear half first. The footrest and the dashboard/steering box are 3D printed parts.  I am using Prismacolor Premier pencils, Oil paints, finely sifted real dirt and Bragdon weathering pigments. Fortunately, the Fordson tractor could (and often did) leak oil out of pretty much every seam and joint.
Despite your having less time for modeling, the artistry seems consistent with your usual adequate standards. -- Russ
Now that Nick has thrown down the gauntlet, its time for him to show all of us how it is done.  I personally want to see 1/32 scale working spark-plugs from him.
Looks realistic to me!
Looks like a cross between a Sea-doo and a Star Wars Starfighter - but, it looks really good.
Arrrgh! That's exactly what I meant: some random scratches here, some supposedly accidental scratches there!
And all that finally results in... a masterpiece! :o
Hi Chuck - The Prismacolor pencils  "me being a bit thick in this area " can you give us a brief description of process of using them in conjunction with the other bits e.g. oil paints and Bragdon pigments how do you start ? to achieve this amazing finish !
and Im sure a few others !
Quote from: Lawton Maner on April 07, 2019, 04:02:55 PM
Yes , well , er, I'm a bit busy at the moment getting ready for a trip Down Under but I'll get straight onto it when I get back . Promise .
Oh, good. For a moment I thought you might try to weasel out of accepting that challenge. -- Russ
I think he's fleeing to the end of the world.
